v5.06 (5.06.1322.1) released on Jan. 26th, 2026
Please update using the Hub.
If you do still encounter issues after updating to v5.06, please continue to discuss them in this thread, but importantly also report the issue in the Feedback Tracker to get the issue logged and investigated. Thank you.
Several bug fixes.
Fixed
- Apply Content
The eyeball mesh shrinks when applied to a loaded male or female base character.
Continuously applied eyelashes become distorted when applied to a SubD 2 character and after switching to a different subdivision level.
- General
- Random cache data corruption when downloading content causes the incorrect “Server not responding…” error message to appear, prompting the user to reinstall the content. Feedback Tracker
- Export FBX
“Jaw Open” does not work for characters transferred via Auto Setup for UE (All-in-One) 2.0.
Incomplete JSON data exported from the trial version of Character Creator, causing an error when imported into Unity. Forum Post
Character Creator crashes when “Export OBJ > Eye Part” is performed on a character that has wrinkles applied.
An error message appears when exporting certain characters (e.g., Clothed Ariana, HD Gribro) to Substance Painter.
- GoZ
- GoZ transfer fails on certain computers if the Reallusion folder is missing in the system Documents. Character Creator now automatically creates a replacement folder when needed.
- Replace Mesh
- Re-importing an object with “Replace Mesh” enabled does not update it in Character Creator. Normally, the object’s shape should update, or an error message should appear. Feedback Tracker
- Transformer
A pure white neutral character appears in the viewport, and the Transformer panel does not show for certain Daz G9 characters wearing G9 or G8.1 shoes that were imported into Character Creator via the Transformer.
Some Daz G8 or G8.1 characters had distorted clothing when transferred into Character Creator via the Transformer. Forum Post
- ActorMIXER PRO
- An error message appears when pressing the “Randomize” button in the “Random Face Settings” panel after assigning a custom directory for Head Skin. Forum Post
