Understood, thank you very much. The issue has been temporarily resolved. I hope this bug can be fixed in future updates.
Additionally, I would like to report another issue with ActorMixer: when using the random face generation function, I have to select the entire ActorMixer directory to generate faces if I want to use my own model library. However, I want to categorize my model library—for example, into Realistic Male/Realistic Female/Cartoon Male/Cartoon Female. The only workaround I’ve found is to create these separate folders within the ActorMixer directory and place the complete model libraries inside them. Unfortunately, these manually created folders cannot be recognized by the CC5 Asset Library directory, which has been quite frustrating. Could you please advise me on a solution to this problem?
