Why can’t my ICLONE8 start? However, the task manager shows that ICLONE8 is running in the background, and it can still be used at 7 o’clock this morning. After closing and reopening, it will not work.
You have provided no information regarding your computer specs, or any information about what all was running on your system.
Your issue is also not something that could be correctly answered by Forum users. For expert help you will need to directly contact Reallusion support through the link below.
If you would like to share your system specs including graphics card then this may give an indication of the problem. Do also try updating your graphics drivers, as driver issues are a common cause of issues like this.
However, as wires already advised, if the issue persists, please contact Support and they will try to help you.
This occurred to me several times…
The solution was to close that running IC8 in task manager.
Sometimes it was not possible to close the app with task manager,
a pc restart was the only option then…
I’ve found when iClone starts becoming problematic, I uninstall and reinstall using the Hub and it works fine again.
It’s a fairly painless process, you don’t lose anything when uninstall/reinstall. At worst just need to change preferences/settings etc back to the way you had them.
In fact it’s not a bad idea to do it every so often, because I found it even though I have updated when prompted, the updates don’t always fully install. For example, I’ve been waiting for ages for RL to fix the toolbar where the camera drop down box disappears as there are so many other toolbar options open. Every time I opened iClone, I had to go to the window menu and disable one or more of the other tool bar items so I could see the camera drop down. RL said they would fix it ages ago, but it seemed they hadn’t.
But once I uninstalled and re-installed iClone (for another unrelated issue), the toolbar issue was sorted.
