Greetings,
I am trying to animate a slingshot animation using spring bone or FFD. How could I pin the rubber part to the slingshot handle part so only the rubber part would be stretched.Thanks
          First of all, to Toystorylab, thanks for the kind words. When I wanted to create a sling shot, in my head it worked with using bones in the rubber bands. It did not. It drive me crazy. I ended up animating the slingshot prop using an animated sprite sequence. It did the job I felt.
Thanks both. I’m working using FFD tool. The only problem is that you can’t reduce the number of points. They are sometimes too much. Anyways will share if I make something showable. Thanks again.
10/10 will buy
HI @mikaelworks ,
Remember that we are having a 2D animation contest now! You can develop a bit with your story and submit your final sling shot video to the contest.
Good luck on winning!
