Thank you! Yes, that appears to install everything. However, there are numerous errors in the ComfyUI startup:
[START] Security scan
WARNING: Ignoring invalid distribution ~orch (C:\Program Files\Common Files\Reallusion\RL_ComfyUI\python_embeded\Lib\site-packages)
[DONE] Security scan
Failed to execute startup-script: C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\comfyui-manager\prestartup_script.py / Failed to initialize: Bad git executable.
The git executable must be specified in one of the following ways:
- be included in your $PATH
- be set via $GIT_PYTHON_GIT_EXECUTABLE
- explicitly set via git.refresh()
All git commands will error until this is rectified.
FileNotFoundError: [Errno 2] No such file or directory: ‘C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\.git\init.py’
Cannot import C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes.git module for custom nodes: [Errno 2] No such file or directory: ‘C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\.git\init.py’
Could not find ControlNetPreprocessors nodes
Could not find AdvancedControlNet nodes
Could not find AnimateDiff nodes
Could not load ImpactPack nodes Could not find ImpactPack nodes
ComfyUI-GGUF: Partial torch compile only, consider updating pytorch
Traceback (most recent call last):
File “C:\Program Files\Common Files\Reallusion\RL_ComfyUI\python_embeded\Lib\site-packages\git_init_.py”, line 296, in
refresh()
File “C:\Program Files\Common Files\Reallusion\RL_ComfyUI\python_embeded\Lib\site-packages\git_init_.py”, line 287, in refresh
if not Git.refresh(path=path):
File “C:\Program Files\Common Files\Reallusion\RL_ComfyUI\python_embeded\Lib\site-packages\git\cmd.py”, line 631, in refresh
raise ImportError(err)
ImportError: Bad git executable.
Cannot import C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\comfyui-manager module for custom nodes: Failed to initialize: Bad git executable.
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-LTXVideo
MultiGPU: Module ComfyUI-LTXVideo not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\comfyui-ltxvideo
MultiGPU: Module comfyui-ltxvideo not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-Florence2
MultiGPU: Found ComfyUI-Florence2, creating compatible MultiGPU nodes
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI_bitsandbytes_NF4
MultiGPU: Module ComfyUI_bitsandbytes_NF4 not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\comfyui_bitsandbytes_nf4
MultiGPU: Module comfyui_bitsandbytes_nf4 not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\x-flux-comfyui
MultiGPU: Module x-flux-comfyui not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-MMAudio
MultiGPU: Module ComfyUI-MMAudio not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\comfyui-mmaudio
MultiGPU: Module comfyui-mmaudio not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-GGUF
MultiGPU: Found ComfyUI-GGUF, creating compatible MultiGPU nodes
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\PuLID_ComfyUI
MultiGPU: Module PuLID_ComfyUI not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\pulid_comfyui
MultiGPU: Module pulid_comfyui not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-HunyuanVideoWrapper
MultiGPU: Module ComfyUI-HunyuanVideoWrapper not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\comfyui-hunyuanvideowrapper
MultiGPU: Module comfyui-hunyuanvideowrapper not found - skipping
MultiGPU: Checking for module at C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-WanVideoWrapper
MultiGPU: Found ComfyUI-WanVideoWrapper, creating compatible MultiGPU nodes
Cannot import C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\ComfyUI-SimDA module for custom nodes: No module named ‘diffusers.modeling_utils’
Warning: Could not load sageattention: No module named ‘sageattention’
sageattention package is not installed
WAS Node Suite Warning: ffmpeg_bin_path is not set in C:\Program Files\Common Files\Reallusion\RL_ComfyUI\ComfyUI\custom_nodes\was-node-suite-comfyui\was_suite_config.json config file. Will attempt to use system ffmpeg binaries if available.
Are these expected during the BETA, or do I need to address them?
