iClone crashes when export Toon Seagull
Anyone has the Toon Seagull?
Whenever I try to export, iClone 8 and CC4 crash…
https://marketplace.reallusion.com/toon-seagull
Really annoying as I need for commissioned work ;-(
It works in IC7…
And even loading the seagull to scene makes IC8 crash…
Though this would be not ideal, I could work in IC7,
but unfortunately one can not modify the seagull in cc3, only cc4.
Though I need to modify…
So I can not use for the project as intended, which is bad ;-(
Did you try saving the seagull in Iclone 7 and then reloading in IC 8? It is a legacy product and they can give issues. Sometimes I even have to go back to IC5 to get something working.
Yes, also tried this…
The character loads but iClone 8 always crashes at 62% during export…
I don’t know if the developer, dicho, responds to Market Place messages but he might be able to assist.
I put it in feedback tracker as I don’t think Dicho can do much about it. Seems to be an IC8 issue as it works in IC7 but I will send a message to Dicho when I am in the studio tomorrow…
Thanx
Did you try to download/Install with RDL?
Hm, not sure what you mean with RDL…
Is that the “old” install method?
And if so, is that possible at all with IC8?
Yes, old content can still be installed with RDL executable, though it will install in IC7 Template (that’s how it’s getting installed on my computer). I am not sure it will fix the export issue though. But installed items in IC7 template will load in IC8 just fine.
If export does not work, you may try 3DX and then re-import to CC4 (I am not sure about the scope of your work)
Ok, will check that tomorrow…
Thanx
