This update brings better compatibility with the newly launched Character Creator 5, including MetaHuman facial animation import, CC5 HD support, and Extended-Plus profiles. New eye shaders, Unreal 5 and Marmoset export presets, and timeline and Motion LIVE improvements enhance control and realism. Also includes optimized file compression and key bug fixes for a smoother workflow.
Added:
General
New File > Import MetaHuman Facial Animation function (requires the installation of CC5).
Now supports CC5 HD characters and facial profiles (requires the installation of CC5).
Now compatible with CC3+ Extended-Plus characters (requires the installation of CC5). Extended-Plus profiles are meant for Extended characters that use CC5 corrective shapes.
Eye Elements
New Digital Human_Occlusion (HD) shader for smoother blending between the eyeball and eye socket, creating a subtle fade effect that removes hard edges and prevents visible mesh intersections.
New Digital Human_Tearline (HD) shader to match the updated model and UV layout.
Character
- New subdivision level for already subdivided CC5 characters.
Timeline
- New Facial Parts Strength option in the context menu for quick strengthening of regional expressions.
Export FBX
New preset for Marmoset Toolbag.
New preset for Tear Ducts UV adjustment for Marmoset Toolbag, with the inclusion of other Game Engine presets.
New Unreal (UE5 Skeleton) preset. The existing Unreal preset is renamed Unreal (UE4 Skeleton).
New Unreal 5 (Mannequin) and UEFN options under Export FBX > Advanced Settings > Add Reference Pose.
New Unreal 5 Mannequin profile for characterizing and FBX motion import.
Preference
- New Dynamic Mipmap option in Real-time Render settings for reducing noise when using high-detail textures with General Wrinkles (Live).
- Non-linear Curve support for characters that have corrective expressions in their facial profiles. This includes CC5 HD and CC3+ Extended-Plus profiles.
Enhanced:
General
Better compatibility with Character Creator 5 (see FAQ for details).
Optimized file compression for mesh data and animation, reducing project file size without affecting loading performance (iProject remains uncompressed).
Eye Elements
Modify > Add Eye Elements > Eye Occlusion: Improved model design for tighter fitting around the eye socket.
Modify > Add Eye Elements > Tear Line: Adjusted model and UV layout for better specular highlighting.
Fixed:
General
- iClone no longer crashes when certain characters are imported. Feedback Tracker
Export FBX
- CC3+ Base in UE5.6 Control Rig now have the correct right-hand controller. Feedback Tracker 1, Feedback Tracker 2
Motion Editing
Certain operations with the Edit Motion Layer and Motion Direction Control no longer causes the character to move forward perpetually.
Project sizes no longer increases with each application of the Flatten All Layers command. Feedback Tracker
Render Video
Removed uncompressed rendering with Render Video > AVI Export. Feedback Tracker
Images no longer render with mosaic patterns when the Performance > Enable DLSS is enabled. Feedback Tracker
