<EVENT> Share Your RTX Renders and Get 500 Bonus Points
I took another existing project as a basis for an RTX render. This project I used as first-frame-last-frame for an AI video render.
Because of differences on how lighting is interpreted, my DX render is an approximation of the scene. I noticed that I have to increase the lighting strengths for RTX to see an effect.
DX Render:
RTX Render:
Render time: 3 minutes for 1080x720.
RTX render of “last frame”:
For technical details and settings see my previous post: <EVENT> Share Your RTX Renders and Get 500 Bonus Points - #39 by animagic
For this scene I replaced the materials of the wine glass with RTX materials from the library. “Glass” for the glass and “Ruby” for the wine. I tried “Glass” for the windows but for some reason there was kind of a lens effect, so I gave up on that.
My own RTX render project. It’s really cool, I really liked it. It threw an error once and kicked me out of the program while trying to render a face too close. There were no problems with installation or rendering except for the one instance mentioned above.
Your image links don’t work for me.
You can include an image in your post by clicking the image icon (highlighted below):
This will open a file browser.
You can also just drag the image inyour post and it will be included.
You can also paste any image on your clipboard directly into the message at your cursor location.
Hi, vik.kartel2005_33
Thanks for joining the beta program!
Could you please upload your render results again? We can’t see the images at the moment.
Thanks for the advice, but no matter how I take the photos, they won’t upload.
Here’s another test.
Image 1: Native render
Image 2: RTX render
Best regards, Robert
These are renders with just my own lamps added. I wanted to check how the render would display within my own settings.
I had not used the CC5 RTX Beta yet, so this was done with Beta 2. The charcater was created in CC5. I placed her into a set: “Armed Forces and Industrial Interiors - Terr*rist Base”. This is an older product, so to improve the look I upscaled the closely visible textures with Topaz Gigapixel.
Resolution 1920x1080, otherwise default settings for the renderer.
Render time: 2 min+4 sec.
I used glow maps for the computer screen and for the window in the back. I also adjusted some of the lighting. I think it turned out nice.
Hello, I wanted to thank you for your advice. The problem was this: I was uploading photos to a chat opened in Google Chrome, and it wouldn’t let me upload them. I was able to upload them to Edge. Thank you very much for your help and participation; it means a lot.
I was curious how video rendering would work out. My first attempt gave an error:
I had seen this error once before, but an addtional attempt was successful.
Although it is attractive to render at 4k with a lot of samples, it is slow, as people have found out. For my AI work, I mostly render at 720p and then I use Upscayl to upscale to 4k. So I tried the same here.
The orginal video has the following specs: Video: 720p 192 samples 24 fps 122 frames (about 5 seconds).
I have started working with 24fps, because that is what most AI models will give you, so I’ve done the same here.
This is the final video:
Just a render of one of my main characters.
DX11 Render
RTX Render
Here’s another attempt:
Image 2: RTX render
I’m so happy that I successfully rendered my first image. I hope the official version will be released soon.
Here’s a test with Volometric Light.
I’ve finally started in Beta 2 and here’s a first comparison test from CC5.
DX11 render:
RTX render:
System:
Win 11 Pro
Intel i9 285K 3.7 GHz
PNY RTX 5080 16 GB
32 GB RAM
Renders were done using the default settings.
I achieved excellent results. The reflections and refractions between the materials are truly impressive.
These 2 guys have talked each other to death in iClone.
DX11
RTX
All render settings are default.
Next task is to get to grips with the RTX lighting.
Using CC5 and HS3, I recreated a character I did last year. I then placed her in an environment, and rendered using RTX Render:
The equivalent DX render is below:
I didn’t change anything major in this case, but I did optimize the lighting for RTX. This overexposes the DX render.
