Chracter Creator v5.05 (5.05.1305.1) released on Jan. 6th, 2026
The latest CC 5.05/ CC4.65 update is now available, bringing multiple enhancements and bug fixes. It also introduces support for Subscription license, ZBrush 2026.1.1, and the ability to convert Daz Genesis characters into CC5 HD using the Transformer.
General
- Support for subscription-based licensing. Learn More
Added
GoZ
- Support for ZBrush 2026.1.1 with CC now matching the new transfer directory used by ZBrush.
Content
- 18 new eyelash and eyebrow materials are now available, allowing color changes using the “Ignore Opacity Texture” option.
Transformer
New high-to-low normal baking tool for Daz Transformer (Transformer > High to Low Normal Bake).
New “Get Daz T-Pose” and “Get Daz A-Pose” buttons in the menu and toolbar.
Enhanced
ActorMIXER PRO
- ActorMIXER PRO > Random Face now supports multiple target asset folders for the Content Manager.
Performance
Progressive texture loading is now set to use 100% of CPU processing by default to accelerate texture loading.
Entering and exiting Adjust Bone, Spring, Proportion, and Facial Profile modes is now faster.
Transformer
Daz characters can now be converted to CC5 HD characters via the Transformer (Menu > Create > Transformer > CC5 HD). More tutorials will be coming up
G9 male and female preset with topology mapping data are now provided for Daz Transformer.
Daz Transformer now includes updated topology mapping for Daz G8, G8.1, and G9. Adjustments cover the nasolabial folds, chest, belly button, wrist line, and chin line, with mesh stretching around the toes and ears removed.
Export FBX
- Exporting certain characters with missing key humanoid bones using the Unreal (UE5 Skeleton) preset triggered an error message and automatically switched the export to the Unreal UE4 Skeleton preset. Forum Post
Load File
- Applying Individual (Flatten) Wrinkles now triggers a dialog reminding users that Individualized Wrinkles are designed for specific characters with fixed skin tones. The message also includes a link to a tutorial.
Render
- Loading certain projects with the Blur or Lens Blur post effect enabled triggers a message warning that the final render may appear darker than usual. Feedback Tracker
Fixed
General
Error message upon activating Help > Activate Entire Library.
Tooltip videos not playing within the application.
Save Layout not storing the current state of the toolbar with the toolbar resetting every time the application is launched. Feedback Tracker 1, Feedback Tracker 2
Load File
Applying certain content packs, such as the Combo Mouth Shape for Chinese and Japanese, triggers a message stating “Can’t load invalid data.”, rendering the pack unusable.
Unable to apply certain saved characters, including those saved within a project, due to irregular texture data that triggers a “Failed to load” message.
Mesh distortion when applying certain clothing and shoes, such as the C_High Top Shoes from the Casual High Top Shoes content pack. Feedback Tracker
Applying other hair assets caused an application crash after performing Polygon Reduction – Object on certain hair content (e.g. Lite Hair series and Hair Builder series).
Render
- There is a significant difference in the roughness map between the head and body of the HD Neutral Female character when viewed in Roughness mode. Please update the content via Content Manager. Feedback Tracker
AccuRIG
- Abnormal facial animations with characters created from “AccuRIG > Generate Skeleton (Keep Existing Set) > Bind Skin”.
Editing
- Faceted mesh appearing on the eyelids of some HD characters when “Character > Correct Eyeblink” is executed.
Export iAvatar
- CC crashes when trying to export the Neutral_M or Neutral_F characters. Feedback Tracker
Export FBX
Abnormal rendering of the hair for characters that are exported to Blender via Auto Setup.
Three sets of repeating morphs (including some faulty ones) may appear on certain characters exported with the UE preset when the Mouth Open as Morph is enabled.
Wrinkle texture maps may reach 8K resolution under 8K texture export settings, even when such high resolution is unnecessary.
Unable to disable Advanced Settings > A-Pose for UEFN when exporting props to Unreal.
Certain hair content, such as the “Light Hair” and “Hair Builder” series, cannot be exported in FBX format after applying Polygon Reduction. Feedback Tracker
Unable to disable Embed Textures when exporting a character with Target Tool Preset set to Marmoset Toolbag.
Abnormal collision shapes may occur with certain characters (such as the embedded CC3+ Baby) when transferred to Unreal via Auto Setup.
Skin and hair colors may appear different in Unreal compared to iClone when transferring a character FBX with Bake diffuse maps from skin color enabled using Auto Setup.
GoZ
Can’t update a humanoid character, props when Zplugin > CC GoZ Plus is performed with with SubD 0 - 2 enabled.
ZBrush is not switching to subdivision level 3 when a CC5 HD character is transferred with subdivision level 2 enabled in CC.(CC SubD2 = ZB SDiv 3)
Character is offset when relink is performed on a character with low subdivision in CC and high subdivision in ZBrush.
When the character SubD Preview Level is set to Level 2 and sent to ZBrush, ZBrush displays SubDiv Level 3, but the viewport mesh still appears unsmoothed, similar to SubD Level 1.
Missing mesh data on certain ZBrush projects that were transfered via the relink mechanism of CC GoZ Plus.
CC crashes when Create Accessory is enabled in the GoZ Options and no character is loaded in CC.
Executing ZPlugin > CC GoZ Plus > Visible after editing character accessories in ZBrush displayed an error message and failed to update the changes back to Character Creator.
Import FBX
- Application crashes when “Convert All” is performed on certain characters (FBX Options: Motion), including the “Character Pack > Horse” character.
Optimize and Decimate
Error message appears when applying InstaLOD > Polygon Reduction-wearables on certain characters, including HD Aaron_Clothed and HD Ariana_Clothed.
Certain hair content, such as the “Back-swept Top” hair from the “Hair Builder 3 – Edgy Pack”, triggers an error message after executing InstaLOD > Polygon Reduction. Feedback Tracker
SkinGen
- The application crashes when applying the Cross Dry skin (via Content Manager > Skin > Acquired) and changing the Texture Size to 4096 x 4096 under Modify > Appearance > Skin.
LipsSync
- Executing Create Script TTS did not drive lip animation on characters re-imported from edited FBX files using Mesh and Expression Sequence. Feedback Tracker
v4.65 (4.65.4905.1) released on Jan. 6th, 2026
Added function, enhancements, and several bug fixes.
Added
GoZ
Transformer
- New “Get Daz T-Pose” and “Get Daz A-Pose” buttons in the menu and toolbar.
Enhanced
Performance
- Transformer
Export FBX
Load File
Render
Fixed
General
Load File
AccuRIG
Export iAvatar
Export FBX
GoZ
Import FBX
- Certain hair content, such as the “Back-swept Top” hair from the “Hair Builder 3 – Edgy Pack”, triggers an error message after executing InstaLOD > Polygon Reduction. Feedback Tracker
SkinGen
LipsSync
