I’m able to import my zbrush model to CC4 via GoZ just fine
I pose it, but when i go to use GoZ to relink it back to Zbrush i get this message
“Some Diffuse/Normals maps are missing from the model, which may complicate the export process. If this was intentional, press OK to proceed. Otherwise press Cancel to review your texture map settings.”
I hit OK, and nothing happens. i’ve tried enabling goZ plus, disabling it, even creating new instead of relink. Nothing happens! Just the same message over and over. Any help would be greatly appreciated!!
Hi
You can ignore the message. That is checking the texture when GoZ to ZBrush.
Please go to the following location and check whether there is a Reallusion folder:
C:\Users[Username]\Documents\
If the folder does not exist, please create it manually, and then re-open CC, and GoZ.
After checking with R&D, we found that some changes made for ZBrush 2026.1.1 data transfer did not fully cover all cases. We sincerely apologize for the inconvenience.
Before a patch is released, please use this workaround first.
I have a Reallusion folder in my documents. The Goz files are there but they’ve to be imported manually into Zbrush instead of having a live link between the 2 programmes. Can you advise? I’m using CC5 and Zbrush 2022. The CCGoz.zsc file is missing in my Pixologic Zstartup plugins folder so I’ve been unable to get the file to appear after hitting GoZ in CC5.
