Animate Ocean Waves
The ocean waves are generated with a Python script.
The project includes two animated water layers, a sky, and moving clouds.
Simply add it to your own scene and swap the water textures to create completely different ocean styles.
The Python script is not included.
https://marketplace.reallusion.com/ocean-waves-710228
Just picked this up and gave it a spin. Swapping out the normal maps and tweaking the opacity to make a murky swamp instead of an ocean worked like a charm! Real time-saver, especially since the looping is seamless.
Thank you litumipube46, I’m glad you can use it.
Have a good time
Tesira
Great asset! , but It would have been perfect if the Python script was included too.
Well yes wolvatbll0.
You have read, why I could not include the script? It dos need additional Python components. I have given a Link to the script and also written, what all must be done, to get it to run. It is really not so easy to do it only with RLPy, but will look, what I can do more. Here you can see more: Waves for iClone
Greetings Tesira
Thanks for the clarification, Tesira. I understand now why the script requires additional Python components and why it can’t be handled entirely through RLPy. I’ll check out the Waves for iClone thread as well. I appreciate you sharing the details and the script.
