I cant get this to work at all and I have scoured the forum, and spent hours on trying to get a non destructive transfer back and forth. Followed The Michael Pavlovich tutorials on Youtube to start with but it wont work.
My issues is the following:
When sending from CC 5 to Zbrush, Zbrush will apply the CC Detail Layer once and then add another layer to the layer tab. It doesn’t matter if I delete or keep the old layer before exporting, and it doesn’t matter if I change the export options in CC5.
Secondly when trying to send from Zbrush to CC5 90 % of the time it will change to a Create Cloth, not update. Especially when trying to actually add SubD in Zbrush to start add secondary details. When Pavlovich demonstrated it could be done, it was no problem for him to send it back to CC5.
What I have done: Clear cache and restart GoZ Plus every time, Reinstalled everything.
I am at a loss on how I can use this software at all. The Contest is stalling and I really want to buy the software afterwards but nothing is smooth when I cant even GoZ properly. It keeps on adding that damn CC detail Layer all the time and keep on breaking the transfer
We couldn’t replicate your issue. We would like to understand better what you are trying to achieve.
Regarding the first issue, regardless of the settings in Character Creator or whether the layers are cleared in ZBrush, a corresponding layer will still be created. These layers are primarily used for applying normal maps. You can choose not to send the normal map, but a layer with the corresponding name will still be created.
When using Relink, there is an option to choose whether to create a new layer. This is intended for users who want to preserve different mesh variations or appearances in ZBrush.
Regarding the second issue, we can only confirm that the object is recognized as Create Cloth when it is sent back to Character Creator. We will need more information about what was sent, how the object was created, and your complete workflow to investigate further. Could you please provide a screen recording showing the process? Please send your files to winnerhung@reallusion.com or a drive link
