Weights change after saving asset and reapplying
Step by step process.
  • Import Fbx as Prop
  • Force to 60fps
  • Pick parent, assign to Root
  • Transfer Skin Weights
    Works like a charm, results as expected.
  • Save asset
  • Delete from scene
  • Re-apply saved asset
    Weights have changed in some way.
For example, because I can’t upload an image to this post. Setting up a shirt with changeable sleeves, where the base shirt is closer to a tank top, and the left and right sleeves can be attached.
When first set up and tested, it would move and work properly. Then, when re-applying, the sleeves would no longer line up with the torso section of the shirt. Character Creator, you did so good from the start, why would you change it?
