Usability & Workflow Suggestions
Adjustable scroll sensitivity in the Content Browser:
The current scroll speed is very low, which results in excessive scrolling.
Improved folder navigation:
Allow navigation through folders and content using the arrow keys (up/down).
It would be very helpful to reuse keys that are already assigned in other shortcuts:
For example, if ALT + LMB is used for orbiting the camera, the ALT key cannot be used together with RMB for other shortcuts. ALT becomes unavailable (grayed out), while ALT + MMB still works — this behavior is unclear and restrictive.
Fly camera controls using WASD for more intuitive scene navigation.
Reset buttons for parameters (e.g., morphs):
Provide a way to quickly reset values to their default or previously set value with a single click, instead of manually re-entering numbers.
Clear indication of purchased content in the store:
It should be immediately visible which assets have already been purchased, to avoid manually comparing with the user’s library.
Hi…
Thank you for the feedback.
Please remember to also post this in the Feedback Tracker. The FT is the best way to get feature requests logged and considered for future updates. Thanks.
