Sticking bones on FBX export
Upon exporting the character from CC4 with FBX format the bones are sticking out of nipples and the feet. This is causing issue as per Marvelour Designer tech support when we import the character. The issue is it does not create automatic arrangement points and auto fitting suit. Does anyone know how to solve this issue?
What is the suit and points look like in MD after you import the avatar?
This is mine - a Neutral Male exported in A-pose from CC
Thanks for the reply. Sorry i was unwell so couldn’t reply earlier. So the issue is I do not see the fitting suit option as its not created. I am using the latest version of MD, so it no longer shows like this it shows like a black mesh on the full body. But when its not able to create it then it does not show up anything unless we create the fitting suit manually. Which version are you using? It looks like the latest version has the issue with FBX format. With OBJ , I do not have the issue. I want to use FBX for animation.
I am using MD 10, but it does not have automated suit creation routine. Got to create manually regardless.
