Solved - Serious Issue with FBX Import in CC5 – Can't Edit or Move!
I’m having a serious problem when importing an FBX file as an accessory in CC5.
As soon as I import the file, I can’t move, modify, or delete it at all. The only option available is mesh editing, which is completely useless in this case. I literally can’t do anything with it!
This is extremely frustrating. I’m trying to create a custom outfit, but this issue is stopping everything. I need this fixed ASAP.
Please help!
Hi…
A patch is coming for CC5 to fix some known issues. However, if you install the latest AI Render Plug-in HERE you may find some of these issues are already fixed.
If you don’t want to install the AI Render Plug-in, then please see the thread HERE where you can find a workaround from Rampa which should help.
Thank you very much.
For now, I was able to resolve the issue by converting the FBX file into an OBJ file before importing.
For some reason, the performance has noticeably improved compared to when I first launched CC5 — both when loading files and when exporting to Blender.
I am truly satisfied with the results!
