when you use edit on seedance 2.5 you can’t place the images or the ai actors, there references always show at bottom, you need to drag the referente where you need to put it, son in big prompt is a little anoyed.
Hi masmore,
Could you send us a screen recording showing the issue? Are you referring to Video Gen — Edit , as shown in the reference image below?
Regards
Sure this what happend in this seccion when you at some ai actor
you write your prompt and choose that ai actor to place it as reference imagen
everytime it send the reference to the botton no the section you select like any other place in ai studio only in edit that happend
Hi masmore,
Do you mean you’re trying to add a reference while typing a long prompt? The easiest way is to type “@” and select the reference you want to add.
Regards
Hi @masmore ,
Thanks a lot for catching and reporting this bug! Our team will fix it in the next update.
Really appreciate your support!
Thanks
