A question I couldn’t find the answer in tutorial.
Assume I already have an animation downloaded from RL content store, I want to add some facial animation on it using RL’s tool in CC5. After that, I want to export facial and body animation in a “single” FBX and import it in UE5. I don’t want to separate the facial and body into two fbx then combine them in UE5. I don’t want to deal with meta human in UE5 either. The facial animation could be generated by AccuFace or by any other method but has to be done in CC5.
Is that a possible thing?
Hi meowyih,
If you only need to apply facial or body animation templates, you can do so directly in Character Creator 5. However, if you plan to create or edit keyframe animations, you will need to use iClone, as Character Creator does not support animation keyframing.
Regards
Hi Winner_RL,
Thanks. I just successfully added simple animation on iClone and export to UE5. Your hint is very helpful. ![]()
Hi meowyih,
No worries! Glad to know you have successfully exported it to UE5.
Enjoy animating!
Regards
