Did you mean using the Send Mesh button to update the mesh after editing in Blender? Or did you use the Export Replace Mesh button to get an .obj file to replace original one in CC?
In either case, we weren’t able to reproduce the issue at our end. Could you please provide some more detail on your workflow? (Used character, edit process, and if you don’t mind, screenshots or screen recording.)
Everything was working perfectly before I installed Headshot 3. However, now when I use goB to send a character from CC5 to Blender and use “Replace Mesh Sent,” the modifications only apply to the hair and clothes—the body mesh remains unchanged.
This is likely happening because the version on the Hub (2.3.4) is the wrong one and the replace mesh functionality in that version doesn’t work with the latest CC5. The latest version is 2.4.0 and that works with CC5.07.
