Repeatable bug
1 make a morph head,
2 add morph eyes, and morph mouth.
3 go back and update / switch / edit the head graphic with sprite editor - load new graphic.
4 click the eye and mouth feature to readjust to updated image, ( the quick access eye and mouth icons )
it will leave the software hanging. This is because when you replace the head image, it removes the morph mouth and eyes - but the quick edit features still attempts to edit the parts that are no longer there. you have to taskbar - force close the software to escape it.
this happened because i wanted to tweak the head graphic but there is no send to photoeditor option for the head - so I just replaced the graphic and discovered this glitch in the process.
Hi PSD
Thank you for the notification. As well as reporting here, please can you report all suspected issues and bugs in our Feedback Tracker. The tracker is monitored directly by the CTA team who will investigate the issue and give you feedback there. The tracker is the best way to get issues looked into and fixed in a future update.
To use the Feedback Tracker, please click the link below.
Thanks.
Just to add this has been confirmed by the dev team as a bug. They will try to fix it in the next patch. Thanks again for the notification.
Thank you Peter, you’ve always been awesome and imo a key ingredient to keeping it all together! respects!
