Renaming items takes forever in larger projects
Why does it take almost a full minute just to rename an object in a larger project? This is not a new issue, may even go back to iC7 days…
By larger, do you mean regarding the number of items or the size of the project on disk?
One reason might be the way Undo is handled as every change is added to the Undo cache. So it depends on what kind of disk your temp files are.
Hi gordryd… I have passed your feedback to the iClone team. I’ll update again if I get any news about a solution.
UPDATE:
Unfortunately there is no quick fix for this problem, but the dev team will look at improving the renaming speed in a future update.
