Dear Cartoon Animator Team,
I am not sure it is a bug or not, but I was trying to test it many times, so I thought that it is a bug. It still playing audio, even I remove the audio from the voice clips timeline.
Thank you for your support.
Sincerely
Raksmey
Hiā¦
There are four independent audio tracks on the timeline.
When you say you can still hear audio after removing the voice clip, do you mean you can still hear the vocal audio from the voice clip or other sounds?
If the latter, you may still have audio present on the FX1, FX2 or Music tracks of the timeline.
I meant, let see my process steps:
- I clicked Create Script in the left side menu
- Then I clicked Wave File
- So then it is working normally
- But if i clicked on the actor and then I clicked on remove object animation, then I clicked Play the animation; I was still hearing that inserted audio.
Thank you.
Sincerely,
Raksmey
Hi Raksmey
Thank you for explaining more about the issue. We can reproduce the problem so it will need to be fixed in a future update. I have passed this to the CTA team for investigationā¦
Please accept our apologies for the inconvenience this issue causes. For now we recommend removing the voice clip first before using Remove Object Animation.
