Reallusion Hub & Character Creator 5 – Server Connection Errors (Windows 11 Pro)
After updating Reallusion Hub and upgrading to Character Creator 5 and iClone 8, I began experiencing persistent Server Connection errors. Here is the full situation:
Issue Summary
  • Character Creator 5 (CC5) cannot connect to the server.
  • Reallusion Hub also cannot connect to the server.
  • iClone 8, however, connects normally with no issues.
System & Environment
  • Operating System: Windows 11 Pro
  • Reallusion Hub Version: Latest (updated prior to the issue)
  • CC5 and iClone 8: Newly upgraded from CC3 / iClone 7
Troubleshooting Steps Already Performed
  1. Turned off Windows Defender Firewall completely for testing.
  2. Added all relevant Reallusion applications and executable files to the Defender whitelist (allowed apps).
  3. Verified that the system has a stable Internet connection.
  4. Restarted the PC and reinstalled Hub components.
  5. Confirmed that other apps have no connection issues.
Current Behavior
  • CC5 shows repeated server connection errors on startup.
  • Reallusion Hub fails to connect to the server.
  • iClone 8 connects to the server normally, which rules out a general network or firewall issue.
Additional Notes
  • No VPN or proxy is being used.
  • This issue began only after updating the Reallusion Hub and upgrading to CC5.
  • CC3 assets imported into CC5 appear correctly, but server-side features cannot be accessed due to the connection issue.
Hi…
There was an issue with the Reallusion Hub over the weekend that caused connectivity issues, but this should be resolved now.
If you are still having these issues, please contact Technical Support using the form HERE and they will help you. Thanks.
Same issue here, at least with CC5, Hub seems ok. I bought CC5 during the hub issue and now none of the add-ons in the package work (goes into trial mode) and give the connection error when trying to use them. I’ve opened a support ticket but so far have not found a fix for the issue.
@bsgrooms
I’m sorry to hear you are having problems accessing your add-ons. While you wait for Support to get back to you, try logging out of the Hub, close the Hub down and restart, then log back in. This may help.
