I am developing a plug-in to receive our full-body motion capture data to control an avatar in iClone 8. I referenced the IC8 Python API: Modules and part of my code is shown below:
self.body_device = manager.AddBodyDevice(self.avatar_name + “_BodyDevice”)
self.body_device.AddAvatar(self.avatar)
self.body_device.SetEnable(self.avatar, True)
body_setting = self.body_device.GetBodySetting(self.avatar)
body_setting.SetReferenceAvatar(self.avatar)
body_setting.SetActivePart(RLPy.EBodyActivePart_FullBody)
body_setting.SetMotionApplyMode(RLPy.EMotionApplyMode_ReferenceToCoordinate)
self.body_device.SetBodySetting(self.avatar, body_setting)
device_setting = self.body_device.GetDeviceSetting()
device_setting.SetCoordinateOffset(0, [0, 0, 0])
position_setting = device_setting.GetPositionSetting()
rotation_setting = device_setting.GetRotationSetting()
rotation_setting.SetType(RLPy.ERotationType_Quaternion)
rotation_setting.SetQuaternionOrder(RLPy.EQuaternionOrder_XYZW)
rotation_setting.SetCoordinateSpace(RLPy.ECoordinateSpace_Local)
position_setting.SetUnit(RLPy.EPositionUnit_Meters)
position_setting.SetCoordinateSpace(RLPy.ECoordinateSpace_Local)
and initialize the bones :
self.body_device.Initialize(self.bone_list)
self.body_device.SetTPoseData(self.avatar, self.naturel_pose_data)
finally update the bones:
self.body_device.ProcessData(0, self.now_pose_data)
I encountered two problems:
after processing the data, my avatar shifts upward by an offset, as shown in the attached image. Even if I don’t update the now_pose_data, it still happens.
If I move the avatar to a specific position using the gizmo, it snaps back to the world center after processing the mocap data. Could this be caused by the EMotionApplyMode_ReferenceToCoordinate flag?
When I switch to EMotionApplyMode_ReferenceToAvatar, the avatar stays where I placed it, but the rotation becomes incorrect: some avatars rotate 90 degrees around the Z-axis, while others rotate 135 degrees (and so on).
Do I need to convert the mocap hip bone’s rotation data into a specific coordinate system when using EMotionApplyMode_ReferenceToAvatar? The data I’m using is the local transform relative to its parent. In a simple case, the hip’s parent is the avatar’s base object, but the avatar still does not maintain its original facing direction.
I want to keep the avatar at the specific position and rotation I set and start the mocap from that orientation. How can I do this correctly? Are there any sample code or examples available?
Thanks,
B.R
Brian
Hi Brian,
You can find the Mocap API sample code here:
This is the documentation for the Mocap sample:
Hope this helps. Thanks
Johnny
Hi, Johnny.
Thanks for your reply.
I have checked the sample code and the documentation you provided above, but they don’t seem to solve the problems I am facing. I can control the avatar with our mocap device correctly, except for the following two issues:
- Upward offset issue
The image shows the local position data I used for setting the T-pose and processing.
I also printed the local position of the hip bone. After processing the data, we can see an offset compared to its initial state. (The motion data I used are in meters.)
As a result, the avatar is lifted by approximately 10 centimeters from the floor.
- How to make the avatar start mocap at a specific position and rotation?
Should I use the API:
SetMotionApplyMode(RLPy.EMotionApplyMode_ReferenceToAvatar)?
At first, I used RLPy.EMotionApplyMode_ReferenceToCoordinate, but it seems to automatically reset the avatar to the world center. However, when I use ReferenceToAvatar, I encounter the problem shown in the image below.
The avatar remains at the position I set, but its rotation becomes incorrect after processing the data. Do I need to do anything extra when using this mode?
Thanks
B.R
Brian.
Hi, Brian.
Regarding this issue, it looks like your input data is correct. We may need you to provide a sample code so we can clarify the problem. Of course, you can directly call the following API to subtract the offset:
body_device.GetBodySetting(avatar).SetCoordinateOffset(rot, pos)
About the parameter settings of SetMotionApplyMode():
If you still encounter unexpected character orientation when using RLPy.EMotionApplyMode_ReferenceToAvatar, it is likely caused by a mismatch between your character’s facing direction and the world coordinate orientation. You can call the following API to correct the character’s orientation:
init_hip_rot_matrix = RLPy.RMatrix3(RLPy.RMatrix3.IDENTITY)
init_hip_rot_matrix.RotationZ(rot)
device_setting = body_device.GetDeviceSetting()
device_setting.SetInitialHipRotation(init_hip_rot_matrix)
I hope this information is helpful. Thank you.
B.R
Johnny
Hi Johnny.
Here are two questions :
1.Regarding using SetCoordinateOffset(rot, pos) to solve the offset issue:
How do I get the offset first? The offset problem occurs after this step:
So, should I get the offset after processing the data for the first time and then call SetCoordinateOffset?
2.About using the RLPy.EMotionApplyMode_ReferenceToAvatar mode.
In the step init_hip_rot_matrix.RotationZ(rot), what value should be assigned to the rot rotation parameter? Should I get it from the hip’s local transform, or from some other data?
Also, the incorrect rotation occurs after processing the data.
So, should I get or calculate this value after processing the data for the first time?
And how about using the offset function for the issue?
‘body_device.GetBodySetting(avatar).SetCoordinateOffset(rot, pos)’
Here is the part of the code I used in my plugin to update the avatar via the API.
# mocap manager
mocap_manager = RLPy.RGlobal.GetMocapManager()
# get avatar
_mocap_avatar = []
avatar_list = RLPy.RScene.GetAvatars()
if len( avatar_list ) <= 0:
return _mocap_avatar
for avatar in avatar_list:
data = MiAvatar(avatar)
mocap_avatar.append(data)
# setting
self.body_device = manager.AddBodyDevice(self.avatar_name + "_BodyDevice")
# body_setting.SetMotionApplyMode(RLPy.EMotionApplyMode_ReferenceToAvatar)
device_setting.SetMocapCoordinate(RLPy.ECoordinateAxis_Z, RLPy.ECoordinateAxis_NegativeY, RLPy.ECoordinateSystem_RightHand)
# intialize bones
# process data in timer
Thanks,
B.R
Brian.
Hi Johnny,
Thanks for your help.
I tried to get the hip upward offset by using the T-pose data as input when calling the ProcessData function for the first time, and then applied this offset as a parameter for the API:
Finally, the upward offset problem has been solved!
Regarding RLPy.EMotionApplyMode_ReferenceToAvatar and the sample code:
After calling SetInitialHipRotation, I encountered the issue shown in the image below.
It seems another problem needs to be solved when using the
SetInitialHipRotation API.
After some testing, I eventually solved the facing direction issue by using the rot parameter in body_setting.SetCoordinateOffset(rot, pos).
Thank you again for your reply and support.
Best regards,
Brian
Hi Brian
I’m thrilled to hear that all the issues you faced have been resolved!
Honestly, I only lent a small hand—your hard work made it all happen!
Wishing your project smooth progress and the best of luck!
B.R
Johnny
