Please come back with the Iclone Avatar Builder because if you search for Autodesk Character Generator, which is the current name of Evolver, Evolver changed its name to Autodesk Character Generator. The site is still there, but if you log in, it gives an error message, and this needs to be fixed in the new version. But I have an idea: if you go back with the Iclone Avatar Builder, but now powered by Autodesk Character Builder, you will have the option to export the character as a non-standard Iclone character or a G-Evolver character, also from Iclone. These characters are still compatible with Iclone 4 or newer. Also, if you have Iclone 6 or newer, you can put G6 hair, including those that are already installed by default in Iclone 6. You can even put the hair and accessories from the Hottest Hairstyles on the characters. The accessories that you can put on these characters are earrings, but I think you can also put hair with a hat from the G6 characters of Iclone to characters that They are from the iclone avatar builder and of course it will not be in the browser but as a software that you can download
iClone Avatar Builder was discontinued because it was acquired by AutoDesk. So RL developed their own alternative, Character Creator. There is absolutely no business reason for RL to go back to a less capable solution, as you would probably be the only user.
You keep going on about how you don’t like what is currently offered, but you don’t provide a valid reason for RL to return to that.
I like Character Creator 1 and 2 but I want to bring back the Iclone Avatar Builder for Iclone 4 and 5 users because these versions are available for 32-bit Windows and the Character Creator that is for Iclone 6 needs 64-bit Windows only for 64-bit Windows I have the computer that I’m using now and it’s 64-bit so it can run Iclone 6 and Character Creator 1 and 2
Do you realize how costly it is to maintain let alone resurrect 32-bit legacy software?
iClone Avatar Builder was a third-party application (Evolver) that RL adapted. It was not an in-house RL development. What you are requesting is simply not realistic.
In fact, you have a lot of requests (or demands) but by your own admission you have no money. So how would you pay for anything?
