Hello, not shure if this is the proper place to ask.
Does anyone has a short phyton code snipped on hand which i can manipulate ccsliders and / or set the “Character Height” Slider Value in CC 4,52 with ?
This is how I set ccsliders:
import RLPy
def get_first_avatar():
avatars = RLPy.RScene.GetAvatars()
if avatars:
return avatars[0]
return None
def find_morph_id(avatar, morph_name):
shaping_component = avatar.GetAvatarShapingComponent()
categories = shaping_component.GetShapingMorphCatergoryNames()
for category in categories:
ids = shaping_component.GetShapingMorphIDs(category)
names = shaping_component.GetShapingMorphDisplayNames(category)
for i, name in enumerate(names):
if name == morph_name:
return ids[i]
return None
def set_morph_slider(avatar, slider_name, weight):
morph_id = find_morph_id(avatar, slider_name)
if morph_id:
shaping_component.SetShapingMorphWeight(morph_id, weight)
avatar = get_first_avatar()
if avatar:
# character height works in reverse, negative values for taller
set_morph_slider(avatar, "Character Height", -0.9)
Thank you, ive been trying several ways to set a slider value without success. Your snippet seems only to identify the ccslider path names.
I’m trying to set the value of a CC slider (e.g., “Character Height” with path “essential body morphs/pack_full_body6”) . I can find the morph path with GetAvatarShapingComponent().GetShapingMorphIDs(), but I can’t find the correct method to set the slider value. I’ve tried SetMorphValue, SetMorphIntensity, SetMorphStrength, etc., but all result in AttributeError.
What would be the exact RLPy method to set a morph slider value using the morph path (e.g., “essential body morphs/pack_full_body6”)? A code example would be greatly appreciated!
Thanks!
scroll down the code window. It sets the slider value at the end.
Oops, my mistake, that was a big help
Thanks so much !
