I recently did a major hardware upgrade, but I’m seeing zero improvement in working with Viseme tracks.
Deleting or shifting a group of phoneme “letters” still takes an average of 20 seconds to process. This lag happens regardless of where I am in the timeline or how complex the scene is. Considering how many adjustments a 5-minute dialogue scene requires, this 20-second “hang” per edit is a massive workflow killer.
Is there any way to speed up such process? Am I missing something?
I would advise reporting your issue in the Feedback Tracker and the dev team will check to see if there is an issue that needs addressing. They will then give you an update there. Thanks.
I wasn’t able to reproduce the issue by editing viseme track on my end.
Could you clarify if you encountered this issue in all project you’re working on?
If you don’t mind, please provide the project with said issue for us to check: alanyang@reallusion.com
