Older Project files won't load
I have everything in IClone 8 up to date. But for a while I’ve had the issue of a few saved projects failing to load in it. These projects are saved from a backup on an external hard drive. I’m remaking a movie I made years ago. Is there anything I can do to get these project files to load?
Hi…
If the old projects are large, try going into your iClone Preferences (CTRL+P) and in the Real-time Graphics section, change everything to the minimum. Also change your Max texture size to 512 x 512. Then try to load the project.
If it still fails, do check the free hard drive space you have on the C: drive where a lot of temporary files are placed (unless you have changed the Temp folder location to a different drive). Freeing up space may help get the project to load.
I tried both of your suggestions and neither have worked. Is there anything else I could do?
