[Official] 🎉 Welcome to AI Render Open Beta – Start Here!
does it working offline after download all of data models?
Feedback for the Reallusion development team.
  1. AI sucks at fingers
  2. The Photorealistic render is not picking up on facial wrinkles
  3. The resulting AI photos do not really resemble my character that I created, and it takes liberty to remove things like freckles and imperfections, even if I put it to strict settings.
You probably need to make a tutorial video. I can get the UI to do good facial renders, and I can get them consistently to look the way I want, but I have NO IDEA how to do clean, full body renders. The more details the model has (like say - clothes, muscles, veins, tattoos, etc.) the more engine struggles. I’m thinking it’s just because it’s a beta.
Hello, davood.kharmanzar
Yes, if you have downloaded all required models, you could work offline.
I can’t get it to do a full body render. The actual BEST renders I’ve done are all waist up (for guys) and faces (ONLY faces and shoulders) for women. For some reason it really struggles with full body renders. But it is a beta and, I’m not glazing Reallusion at all, but IF they can pull this off - where it can do full body renders of models and it can add backgrounds - it will be epic. But I feel your pain.
Just some testing…you may need to roll your own workflows to get better “oneshot” results
iclone:
RL Render (SDXL Workflow)
ComfyUI
Fingers are a little hammered…but inpainting or even a lora would fix that
The ComfyUI render looks terrific. Just to be clear: that render is from the regular ComfyUI, not the Reallusion plugin version??
Second image is from the Plugin in iclone, third is the same workflow that the plugin uses but from Comfy
Hi all,
Registration is now open for our first AI Render webinar, happening Aug 22, 2025 (PST/PDT)!
In this session, we’ll show you how to set up Flux 1 Dev on cloud GPU and connect it with iClone, unlocking production-level AI image generation with precise 3D guidance.
Webinar Outline:
  1. Launching Cloud GPU & Connecting to iClone
  2. Adding a Custom Flux 1 Dev Workflow to iClone
  3. Flux 1 Dev Overview
  4. Image Workflow Breakdown – LoRA, ControlNet, and recommended render settings for character consistency
  5. Q&A Session
This is the first of three webinars in our AI Render series, and all three are open for registration now. Each session explores a different advanced AI workflow, so be sure to join them all.
:link: Learn more and register here: Reallusion Courses - Free Online Tutorials for 2D & 3D Animations
AI Render: I would like to ask a simple question. In case this doesnt fit my needs can it be uninstalled easily and without leaving GBs of leftovers ?
I had to boost the lighting in the CC4 image to eliminate some artifacts that were happening around the neck and knees.
CC4 Render
Unfortunately, I was not able to retain the character’s Ablinism in the render, in spite of trying several different settings.
However, it’s still not a bad looking render. This was the Cinema Image Style.
Here I tried it out with a frog. Best regards, Robert :grin:
1024*1024
IC8 Render
AI Render
hey,
how can do this to make 30sec video??
is that local render or cloud?
i got this message:
so … can i render videos locally?
I havent installed this yet. Please let me ask another question.
99,99% of the Headshot Characters do not look like the originial , only “similar”. could i fix that with this AI Tool ? If so, THAT would be a real improvement to CC and Headshot, make a char ->exactly look like the source !
in one of the videos, the plugin shows a depthmap and a normal map… Can we just get those exporters out of iClone? I don’t need a whole Comfy/Python install. I already have an ai pipeline to my own tools…, just need iClone to output the control images/videos.
yes, but you would need to train the AI with pictures of your source
it’s all in your history folder when IC Comfy is installed. Comfy’s ControlNets are converting to depth or canny. So if you already have comfy installed you would need to add the custom nodes for ControlNets. Easy to do with the Comfy Manager.
I do all local, but I have a beefy GPU. Wait for the upcoming RL tutorials.
thanks for your reply :]
what is your gpu?
RTX PRO 6000?
5090 ??
GPU RenderBOX??
my preferred hardware to using it with iClone Ai Render:
Renderboxes | The Molecule Air from Renderboxes :joy:
only £108,000.00
after testing some scenarios with ai render, i think its very expensive rendering method …
