Jump to the top of the thread. The links you want exist there. Also, Reallusion has created three webinars on how to use tech.
Thank you for your response .I checked it out which then resulted in my last post.
Hi 0oseven,
I’m sorry to hear that you feel this way. We do provide documentation and a template project for your convenience. If this still doesn’t resolve your issue, could you please share more details so that I can assist you further?
I personally want (and I believe I share many people’s sentiments) a working solution tutorial from start to end on how to do LoRas locally with Comfy UI. I checked a couple of solutions and tried to follow some online tutorials, but that never worked out because of the lack of experience and general problems with custom RL Comfy UI install.
Testing Comfy Wan2.2 - morph transitions
Thanks for responding again .
The templates provided should be adequate but not for animated video because consistency of character is needed and if the only way of getting that is through comfyUI then the required time to learn it is a deterrent .( to me at least.) I know others have difficulty in understanding and have requested more step by step tutorials however I acknowledge if that’s what I want then I have to put the effort into learning but its a time thing . Thank you anyway.
You probably have comfy ui installed when you installed iclone ai render. When you start it up and you see all the things being loaded the very last line is a link to ComfyUI interface. Maybe this helps you.
Thanks, but I already spent quality time with ComfyUI manager trying 2 separate methods attempting to create LoRas locally. Both failed for various reason. Just one of my attempts to follow some online tutorial
AI Render Update is live — now available for iClone & Character Creator Trial users
Highlights: Trial support, Face Detailer toggle, plus stability and workflow fixes.
Update now: Existing users update to iClone 8.6 / CC4.6 first, then install the Patch; first-time installs use the Full ZIP. Note: iClone 8.54 / CC4.54 are no longer supported.
View full release notes & download now: [Official]
AI Render Plugin 1002 Version Release Note
I cant install iClone Ai Render, The Patch is saying that it cant find the Ai Render Plugin?? Your instructions says i have to install the patch first? when i try to install the plugin, it asks for a activation code??? How do i fix this, i have no problems installing the CC Ai plugin, But the iClone Ai Plugin is not having a bar of it???
why can I not render?
Hello, msmedia.biz
My apologies for the late reply.
It seems that AI Render has not been installed in iClone, if the patch installer displays a message saying it can’t find the plugin. Please try installing the iClone 8 (Full) version from the link below:
Installer Download:
https://cdn4.reallusion.com/AI_Render_Beta_1002_for_IC8_Enu_Full.zip
Please give it a try, and reach out to us if you encounter any issues or error messages.
Thanks.
Hello, Sp3c1alk
To help us troubleshoot the issue, could you please provide a bit more information?
- Which preset or workflow are you using — image or video?
- Please share your device details, such as the graphics card and available VRAM.
- Go to Menu → Script → Console Log, and share a screenshot of any error messages that appear.
- If the corresponding history folder exists, please open the item folder and run the workflow (Workflow_Pre.json or Workflow_Gen.json) in ComfyUI.
- If you’re using a local setup, please enter
127.0.0.1:8188in your browser. - If any errors occur, please share the error message or a screenshot with us.
Thank you very much for your cooperation.
I have been trying it out this morning, and so far, I must say, you have outdone yourself… It is amazing. I only ran into one issue so far. It does not like the Pose option,
result
I do have installed the Beta into IClone and I have Comfy also on mt system. My Situation is not good because I sit in a rural Area and I am still downloading Models with the help of Download Manager manually. (The Automatics never worked, they stopped or broke every time. Our Connection is not cabled, it comes through the air. ) I also use all kinds of AI for my project, I need a working solution with stable Characters (created in CC5). I am just a retired hobbyist and are on a tight budget, I hope I get the Beta to work on my lousy System (only 8Gb) . To see what I plan to do you could watch my 1st Test of the Prolog. You can guess then what is fully AI generated and what is simply made in IClone…
If you are bored I could need some Help with the project…
Thanks!
hey,
how can i download Models manually with DownloadManager?
