Hello, contact_329118
Do you plan to connect your own workflow through iClone / Character Creator, or would you like to try our built-in features using your existing ComfyUI setup?
Here are two solutions for different purposes.
1. Connecting to Your Own ComfyUI Workflow
If you want to connect iClone or Character Creator to your own ComfyUI setup, you can use the LAN Server option in the Settings Panel.
You can refer to this guide to create your own AI Tool preset:
[Official]📶Maximize AI Render Performance: Custom Workflow Setup & Tips - #2 by fareast1
Here is our Reallusion Custom Node:
GitHub - reallusion/ComfyUI-Reallusion
2. Trying Our Built-In Features
If you want to try our built-in AI Render features, go to the RL_ComfyUI folder and copy the following files into your ComfyUI directory:
run_comfyui.vbs
check_ap_status.ps1
stop_comfyui.bat
After that, you can select the Local option in the Settings Panel to run ComfyUI directly.
If any embedded presets cause errors in your ComfyUI, check your history folder and review the Workflow_Pre.json or Workflow_Gen.json files to ensure all required custom nodes are installed.
We will soon provide all the necessary custom nodes for our embedded presets, along with an official workflow guide for connecting to your own ComfyUI.
