I picked up the Riot mocap for a music video but I’m a iclone Noob.
Can anyone point me to the iclone tutorial that explains how to set up the two characters-for example in a fight, so they register and interact like the capture?
I’m a bit perplexed by the auto-key in iclone for sure. In Maya I’d just move to and obvious point in the time line, adjust the characters position relative to each other, freeze transformations and move on. No such luck in iclone.
iClone can’t freeze transformations. But you can set your character’s position at frame one, which is basically the same as freezing transformations in Maya.
If you want to edit the mocap animation or have a character’s hand stick to another character’s arm (to make it look like they are grabbing each other), you can use the Reach Target tool in the Modify panel.
You can also refer to this tutorial video and start watching directly from the timestamp in the link (7:47):
