Recently purchased “Arial Fighter” motions pack, but the avatars keep moving out of the scenes I created (too far one way or the other) and the combo motions in the pack are way off center. I forget the way to reset the characters position, but keep the animations on the character? (Option B would be to Create a camera then set the camera to the characters and keyframming a ton of keys which would be more time consuming than just using Accupose and create to motions I want to use) How do I reset the characters position when under “modify” tab is showing it at 0,0,0 position and it is clearly way off the center of the Global widget off the screen but keep the motions intact? Even keyframing in the timeline the avatars positions with this motisns pack still do not respond the way I would like… way to jumpy on positioning
UPDATE:: I found the solution, open the timeline, right click the motion and select “Reset Pivot” and then adjust the position to where I need it to be and I set a dummy object to the position then linked the avatar to a stationary dummy object controller
