Mini Viewport Aspect Ratio not matching camera
All my cameras are set to 16:9 but the mini viewport is stuck showing 4:3 which is the whole work area and not the camera. This makes composing shots for 16:9 impossible. Is there a setting somewhere to change this?
What are your output render settings?
This will determine the aspect ratio of the viewport and the mini viewport.
The aspect ratio of the camera has no influence on that. I just loaded an older project and the camera is at 1.5, but because my render are set to HD, I see the required aspect ratio.
Thanks for the reply. My render settings are set to HD 1920 x 1080 so the aspect ratio is 16:9. It looks like the mini viewport is stuck with showing the entire workspace and not the actual camera view. Hopefully they will change that.
Is your Safe Frame checked ON, in Preferences?
That could be it. I have Safe Frame set to OFF and the MiniView port displays as it should.
Yep, that was it. Thanks.
