I must have something set wrong in MD, my avatar “pauses” when I simply want an uninterrupted walk. I’m holding down the “W” key and the walk starts off fine but from time to time during the “walk” the avatar “pauses” then starts the walk again. Can’t figure what I’m doing.
It “appears” that it has something to do with the avatar. Now it’s a CC3+ so I wouldn’t think there would be a problem but when I tried “Camlia” that avatar worked fine with no “pausing” during a walk. Does anyone have any thoughts? It would be much appreciated !
Wow the crickets were deafening! Not even…“You’re an idiot…try this.” Gald I figured it out
Doesn’t seem to be as much activity on this forum as there used to be…
I don’t use MD too much (so far) – was it the “Motion/Idle Time ratio” thingy?
There’s more life in a graveyard than here Mark.
I’ve never seen so much inactivity on the RL Forums until they threw this mess at us.
Hey bud! Of course in our day…our graveyards were pretty lively !!!
Those were the days Mark.
People were using iClone to animate and not just as a stepping stone to a computer game.
Well said! I guess we’re …out of sync !
Well, I saw your question but didn’t know the answer… Of course, I could have said that…
There is so much new stuff and I’m still catching up myself.
Hi Mark…
Sorry to hear you feel disappointed by the response to your question. Sometimes, especially over weekends, you may find a lack of replies but normally you will get a reply.
As you have said you figured out the problem, do you mind sharing what it was as it will surely help others who may encounter the same issue. Thanks.
It appeared that adjusting the “Matching Speed” slider under Data Setting/Properties in MD Behavior seemed to correct the problem among other slight adjustments in the Properties panel.
