Is it normal that when dragging a point/spot/directional light from the content manager it erases all other point/spot/directional lights on the scene?
The only way to get more then one of these lights working on a scene is via the “create light” menu. Wonder if thats a bug.
The Content Manager provides specific light setups. I assume that is where you drag from?
So Create Light is the way the set up a custom light configuration, which is what I use mostly.
I believe if you do drag+control key the lights will be added. I don’t have iClone at hand so I can’t check that.
Maybe you can tell me this. I try and create a new topic on IClone, and the New is disabled and it says ‘You are not allowed to create new topics in this forum’
Have you ever seen that?
For .iLight format:
Left Mouse Click+drag is replacing lights in the scene
Right Mouse Click+drag is adding lights to the scene
When saving to this format, all scene lights are added to the file.
@Data_Juggler
Like in old forum you have to select subcategory
Awesome hint, Thanks ! ![]()
Thanks. It started working after I posted. I guess I was in a subcategory after reading your post.
