I drew a desk for a scene. A bit of brown was floating above. I used the mask editor. it removed it. two weeks later it shows up. i go back to the mask editor; shows the brown spot highlighted as if to say “yes” i WORK. Mask editor isn’t EFFIN working.? bug problem in coding i presume.
Hi… If you believe there is an issue with the Mask Editor, please can you report it in the Feedback Tracker and the CTA team will investigate. If you can provide step by step instructions to reproduce the issue, or a video capture showing the problem, then this will help greatly. Thanks.
