Import issue
I exported an Actor Build version of my character, and I’m trying to import it into Max, but the Auto Setup is freezing at 75% while “Compiling Materials…”. It does let me cancel the whole operation, but no matter how many times I try, even if I restart Max, it does the same thing.
      • update - - - -
        Apparently this only happens with VRay 7. I just successfully did an import with the Auto Setup set to Arnold. I shall convert the materials.
I’m still unable to use CC Auto Setup with 3DS Max 2025 with VRay 7. It stops at compiling materials. Importing into Max 2024 with VRay 6 seems to work fine though.
Also, feature request:
It would be nice if the Auto Setup would create Biped or CAT rigs that have all the same twist links that the imported rig does, and constrain them, so I don’t have to do that by hand.
Thanks.
Please can you report the issue in the Feedback Tracker and the dev team will investigate. If you can supply a screen capture video showing the issue occurring then that will help greatly. Thanks.
Hi, Geoff.
Have you found a solution? I have the same problem. Import hangs at 97% when I try to import for vray 7 hotfix 2 (same with hotfix 1).
regards, urig
Nope, I did not. Hopefully they’ll get to fixing that now that Character Creator 5 is on the verge of being released.
