Image Gen: Appearance prompt vs Style and Feature prompt?
I put my appearance prompt into the appearance prompt text area, chose realistic in the style area pop-up and when I clicked Generate I didn’t get a character that is anywhere close to the appearance prompt. I cut the text out of the appearance prompt and pasted it unchanged into the style prompt and it generated a character that did follow the prompt. Is this a bug? Should the appearance prompt actually work? Or should I only use the style/feature box?
Hi…
The Appearance Prompt is used with AI Actors which is why you will see it in that section. Once you load the AI Actor and click on it, the prompt box will be filled automatically with a description of the AI Actor.
If you are not using an AI Actor, then you just describe your actor in the general text prompt section which (as you have found) will give correct results.
Thanks for the reply! Got it, wish it was clearer but maybe those who use Reallusion tools already this is obvious. Cheers
