I used the special Mocap promotion to generate lots of different dancing motions. However, I couldn’t find a way to display the waveform of the imported audio file to precisely match/adjust the speed of the generated motion to the beats (and cue events), as you get when importing speech. Is there a way to do that?
Update: I found a workaround for adjusting the speed (using beatdetection in Virtual DJ, which shows you the beatdifference not only in bpm, but also with a percentage value, so that is precise enough when using “set speed”), but I would still prefer to see the waveform, if there is such an option. Thanks.
