I want to show only the upper body of my character, focusing on the head, neck and shoulders, but I’m having trouble with the background.
The problem is that I can adjust the view so that the head and shoulders fill the frame, but when I do this, the background shifts and looks very strange. See picture.
My scene contains separate background objects, which are listed individually in the Scene Manager under a top-level entry called “Scene”. Could the way these objects are organised be related to the problem?
In the Modify panel, check the focal length of the camera. Anything below 50mm is considered “wide angle”, which will distort the picture. Set to a level 50mm or higher and then move the camera to get the framing you want.
You have a couple of objects (picture frames, objects from a table, back wall) which might have been unintentionally animated on a timeline. If by the “background shifts” you mean them moving out of place, you have to reset animation for those objects on frame 0.
Or maybe those objects linked to a camera. When you zoom, objects are moving along.
Thank you all for taking the time to help! I appreciate your suggestions. The idea of adjusting the camera’s focal length instead of moving it forward sounds promising, so I’ll give it a try when I have some time to experiment. I’ll report back here on the forum once I have.
I’m still working on this scene. The idea is for the character to tilt her head toward one shoulder, return to an upright position, and then tilt toward the other shoulder. Initially, I couldn’t zoom in on the character’s head and shoulders without the background becoming distorted. Eventually, that problem was solved by using the Preview camera. With this camera, I could zoom in using the Focal Length setting while keeping the background looking normal. I continued working on the scene. Unfortunately, I’m still running into problems.
1. The neck doesn’t move with the head.
My character is a standard Character Creator character. I’m using the rotation gizmo in FK mode on the character. When I rotate the head, the neck doesn’t follow. I can even rotate the head 180 degrees until the face points toward the back of the character. While researching this problem, I came across the terms parent bones and child bones. From what I could gather, rotating a parent bone in FK mode should also affect its child bones. That doesn’t seem to happen in my case.
2. The background moves or gets mirrored, too.
My scene is a furnished 3D living room that of course needs to remain completely static. However, when I mirror the character’s pose to create the stretch on the opposite side, the living room gets mirrored as well. I suspect this might be related to my earlier problem.
I’ve spent several hours trying to figure these things out and researching possible solutions. However, I’ve reached the point where some guidance from experienced users would save me a lot of future time because I’m no closer to a solution than when I first started with this scene.
Thanks in advance for your help!
![Problem 2026.10.19|690x388]
![Problem 2026.10.19|690x118]
If I understood you correctly, you rotate a Head bone and background objects are twisting along. It seems you have a Scene object (or portion of it if you customized objects hierarchy in Scene Manager) linked to a character. Particularly to the Head bone.
On frame 0 select a Scene object and go to its Attributes property tab. You might see something like pictured in Linkage section
Click Unlink
If you do not see anything there, then select every object in Scene Manager until you find what object is linked to character bones.
Background objects could also be Attached to a character. This is a little different than Linking and is less likely the issue because attaching actually moves an object visibly in Scene Manager to a character hierarchy.
After unlinking I recommend to use Remove Scene Animation for the First frame to clear all keys which might have been created down the time line.
FK/IK topic can be confusing. But do not rotate Head bone in FK mode (that is from within FK tab). Head is the last bone and always considerate to be a child in FK mode.
To learn more about IK/FK basics chat with Google Gemini, ChatGPT… etc. Those “guys” have enough training to explain you in details on a lot of topics and iClone particularly (though they can make mistakes occasionally ).
If this the stock loft interior scene, you could also just delete it and add it to your scene again. That would insure nothing is attached to your character, or has been inadvertently moved from its initial position.
It worked @4u2ges I suspected the solution would turn out to be quick and simple, and you proved me right!
I did consult AI extensively, and I learned a few new things about iClone along the way. However, this experience has made me realize that AI still lacks the flexibility of the human brain, and it wasn’t able to come up with the solution. That said, I’ll definitely keep consulting AI before asking for help on the forum. After all, I never have to worry about bothering it, and I get suggestions right away while I’m working on my project. There’s always a chance that one of them will be useful!
I’ve been away from iClone for quite a while, but I’m picking it up again now, and I’m beginning to realize that maybe iClone isn’t actually as difficult as I thought. I keep discovering that you can do quite a lot with just a few tweaks. The problem is that, when you’re starting out, the sheer number of possibilities is overwhelming and intimidating. But the more I learn, the less intimidating it becomes. This time, I want to stick with it and see what I can accomplish.
I appreciate you taking the time to make an annotated screenshot, @4u2ges. It helped me make sure I was looking in exactly the right spot. Thanks for going the extra mile!
Shirley
could you perhaps point me in the right direction again? I’m working on a walking animation, but I’m struggling with foot sliding. Ideally, each foot should stay planted on the ground while it’s supporting the character’s weight, instead of sliding along the floor as if the character were walking on a treadmill, or walking in place without actually moving forward.
I’ve tried adjusting the walking speed, but that didn’t solve the problem. I also experimented with Motion Direction Control, but that didn’t help either.
AI suggested using Motion Correction to fix the foot sliding. However, the option was greyed out on my motion clip. After (much) experimenting, I discovered that using Split → Split Selected on the Motion track made Motion Correction available.
Unfortunately, even though I can now access Motion Correction, I haven’t managed to get a good result with it. The correction range is very short after I split the clip, and working with the separate sections hasn’t solved the problem. I also tried experimenting with a different character, but that didn’t help either.
I’ve now spent several hours trying different things without making any progress. I suspect the solution might be very simple again!
Could you point me in the right direction again? I’d really appreciate a little guidance on how to eliminate the foot sliding without messing up the walking animation. I did manage to mess it up while experimenting. The result was very strange! Luckily, there’s Undo. Making it better, on the other hand, was a different story!
Generally speaking, there is no simple solution to completely eliminate foot sliding.
Motion Correction is a neat tool, but sometimes it takes a lot to correct the motion.
This is a starting point (if you have not looked at it yet): Reallusion Courses - Free Online Tutorials for 2D & 3D Animations
Not sure which motions you used, but better yet is to find motions which do not give you foot sliding to begin with.
Download free Mixamo Motions converted to iClone format. They are not exactly perfect. But better than working with in-place motions and trying to match a walking distance with translate or using an iClone Path feature.
A bit more advanced and for non-commercial use. I always recommend a huge repository of free Dataset motions from Bandai Namco Research group.
They have an excellent and diverse selection of walk/run and many other types of motions with zero foot sliding issues.
Those are .BVH motions and have to be converted to iClone motions format. A few years back I created a characterization profile for importing those into iClone which can be downloaded from HERE.
Downloaded Dataset.3dxProfile file have to be dropped into: C:\Program Files\Reallusion\iClone 8\Program\Assets\Share\CharaterizeProfiles and iClone restarted.
After that you may easily import any of the Dataset desired motions into iClone From File > Import> Convert External Motion and even batch convert by selecting multiple .bvh files
I used a walking animation from the Content Manager.
Thanks for the links! I’ve had a quick look at them, but I’ll need to explore them a bit more. I had also forgotten about the tutorials you mentioned, so I’ll go through those first.
For now, I’ve removed the walking animation and will work on something else for a while. I’d really like to learn how to create and adjust the movements myself.
