Fixed
Animation
Look at effect is removed from the eyes after setting the “Look at Camera / Target” settings and performing “Menu > Animation > Flatten All Motion with Constraints”. Feedback Tracker
Unexpected deviations from the original expressions when an iTalk is saved and reapplied to the character in certain projects.
Export
Extra static body meshes appeared when exporting SubD 1 and 2 characters as Alembic. Forum Post
Mouth can’t open and suffers from inconsistent animation when mouth animation is export to Unreal via Auto Setup.
Load File
iClone crashes with certain character FBX exports. Feedback Tracker
Texture error after an application crash and unsaved project data is restored.
Excessive hang times when saving motion-plus, applying motion-plus, or replacing a character in the project. Forum Post
Render Image/ Video
- Open plugin cannot use certain content causing the plugin to fail.
Example: PopcornFX Sequencer > Load Preset to List showed an error message; Vehicle Interaction couldn’t find Target Motion.
Python Plugin
- For certain computers, setting render format to mp4 locks the frame rate at 30 fps.
Live Link
- Feet deforms for high-heels wearing characters transferred to Unreal via Live Link. Feedback Tracker
Render
The viewport turns dark and flashes when the Reflection Shader is applied to an object with “Preference > Performance > Enable DLSS” is enabled. Forum Post
Mouth can’t open and suffers from inconsistent animation when mouth animation is export to Unreal via Auto Setup. Forum Post
