I need help loading my image and turning it into a live animation. Where do I start? How can I make it happen?
I need help loading my mascot image for my business. And turning it into a live animation for marketing purposes. How do I do that?
Hi…
You have posted this in the Character Creator forum which is 3D software. You have also tagged Cartoon Animator which is 2D software.
So to be able to point you in the right direction, we need to know if you want a 3D or 2D animated mascot as these use different software to produce.
Note: If you have only have an image as the source media, then Cartoon Animator will be the easiest way to animate your mascot. If you want to go the 3D route then you will need to convert the mascot image into a 3D mesh which is a more advanced procedure.
Also is the mascot a person or animal as again this affects how you would go about creating the character animations.
