I want to add a Reflection key in material settings, but it doesn’t work properly.
This is code I used.
“AddReflectionKey” and “AddTextureWeightKey” ,
Neither of them throws an error, and the key is created, but the set weight is not entered. (I set the weight to be 0.0, but when I check with GetReflection, it still shows 100.0.)
Adding an Opacity key with “AddOpacityKey” in the same way worked perfectly.
Could someone help me please?
