This is for props only. I have a project with multiple prop animations and I wanna reuse them and bring them into a new iClone project. For example in Maya, I can copy/paste them from one project to another but iClone won’t let me open 2 projects at same time. Anyone can advise how to do this in a simple fast way?
Thank you!
You can try the Merge Project option, which is under the File menu. At the dialog that opens, select the props you want to import.
iClone will also retain any animation with a prop when you save it in your Custom content so that is another option. You can simply load the prop in your new scene and the animation should be there.
Thanks a lot @animagic ! Seems pretty straight forward. I will def try that.
It worked really well. Great suggestion. Thanks again!
