Headshot 3 Pipeline
I don’t fully understand how to use Headshot 3 to create CC5 level characters. Every time I create a character with it, I seem to end up with a CC3+ level character with really limited morph capabilities and I do not understand how to transition to a multi-level model and regain access to all the complex morphs that should be available. The simple tuts that are up now don’t cover any of that stuff. I’d be grateful if anyone can help with this issue.
Thanks!
When you generate the character you then get the preset morphs from the initial setup in the morph window. You have to erase the preset tag from the search menu to gain access to all the morphs you would normally use.
Yes the preset tag caught me out completely at first.
OK, that explains it. Great, thanks!
