Headshot 3 – CCHeadshot3 and AIGen folders not generated / Stuck at 10% landmark detection
Hi, I am experiencing a persistent installation and initialization failure with Headshot 3 on Character Creator 5.07. Even after completely resetting Reallusion Hub and reinstalling Headshot 3, the plugin does not deploy its required files.
Here are the detailed symptoms:
  1. CCHeadshot3 folder is never generated
The following directory remains missing after installation:
C:\Users\<UserName>\AppData\Local\Reallusion\Character Creator\5.0\5.0\CCHeadshot3
No plugin files or subfolders are created.
  1. AIGen folder is created, but contains only** MemberID.json
Path:
C:\Users\<UserName>\AppData\Local\Reallusion\Character Creator\5.0\5.0\CCHeadshot3\AIGen
Content:
{"MemberID":"xxxxxxxxxxxxxxxx"}
There are no model files, no weights, no configs, and none of the expected AI assets. This indicates that the AI model deployment process fails immediately.
  1. Headshot 3 always stops at 10%
When loading an image:
  • “Loading facial points…” stops at *10%
  • Then shows: **“Failed to detect facial landmarks in the reference image.”
This happens with any image, including default test images.
This error occurs because the AI model files are missing.
  1. What I have already tried (complete reset)
I have already performed all recommended procedures:
  • Uninstalled Headshot 3 from Reallusion Hub
  • Deleted the entire folder:
C:\Users\<UserName>\AppData\Local\Reallusion\Reallusion Hub
  • Deleted any remaining CCHeadshot3 / AIGen folders
  • Restarted Windows
  • Reinstalled Headshot 3
  • Launched CC5 as Administrator
Despite this, CCHeadshot3 is still not generated, and AIGen contains only MemberID.json.
  1. Environment
  • Character Creator 5.07
  • Headshot 3.0
  • Windows 11
  • Reallusion Hub 5.61
  • All products are up to date
  1. Request
It appears that the Headshot 3 installer or model deployment process is failing before extracting the AI model files.
Could you please investigate this issue? If necessary, I can provide logs, screenshots, or run diagnostic builds.
Thank you.
Will suggest to post all
https://www.reallusion.com/CustomerSupport/UserEx/QForm.html?_gl=1*taqz6h*_gcl_au*MTAyNTYyMTE0Mi4xNzc1NDg4NzA0LjY1OTA4MjY0NS4xNzc3NjIxNTgzLjE3Nzc2MjE1OTI.*_ga*MTE0OTQ4NTQzOC4xNzU5ODI1OTE4*_ga_Q3FS71VPKC*czE3Nzc4MTUxNDAkbzI5NCRnMSR0MTc3NzgxNTMzMSRqMTAkbDEkaDIzOTUyMTU2NA
The AI assets are somewhere else. See if you have the following folder:
“C:\Program Files\Reallusion\Character Creator 5\Resource\CCHeadshot3\RLHeadShot3SDK”
There should be files of type “RLAIMODEL”. I have the following:
Hi…
For help with issue please contact Reallusion Support using the form HERE. They will be able to assist you with this problem.
Dear animagic,
Thank you once again for your assistance and for sharing your insights. Your help is greatly appreciated. Unfortunately, the issue remains unresolved on my system, so I will continue looking into possible causes. Thank you for your continued support.
Hi Pete,
Thank you for your guidance. I had opened a support ticket earlier, but I thought posting here might lead to a quicker solution. Understood — I will wait for the official support team’s response. Thanks again for your help.
Hi SUNGOD,
Thank you for your message. I had already submitted a support ticket, and I thought posting here might help me get a faster solution. Understood — I will wait for the official support team’s response. Thanks again for your guidance.
