Hands fingers and bones
Hello, I have a bone issues on my fingers.
They looked good when I rigged them but when I apply the animation it messed up the fingers, shoulders and there is penerating on the arms as the character walks.
How do I fix or adjust the fingers and the collisions?
Hi Adaptable_intelligence,
Is this a custom character? Did you rig using Accurig?
To help us investigate the issue further, could you please provide a screen recording of your complete workflow, along with the relevant project file?
You may send the files to winnerhung@reallusion.com or share them with us via a Google Drive link.
Thanks.
Hi Winner_RL
I have this for example. Not sure still why this is happening. Even when I remapped and realigned my bones to a new character. Then used GOZ to replace and update the mesh from Zbrush it totally crushes my alignment of my bones. But for some reason when I did edit bones and autoalign it aligned them mostly. However, the fingers are still jacked up.
here is a video.
I did NOT use ACCURIG.
Now that you mentioned it I went into Accurig and tried to do some editing… but not sure how to adjust.
https://drive.google.com/drive/folders/1_U_lYGoLIDxu3LR4x3Exs8ni2E7FDK7S?usp=sharing
I think the auto bone alignment may be all you need in the Bone Adjust tool. Now adjust the bone positions in the Proportion tool instead of the Bone Adjust tool. That will adjust the mesh with the bones, so the fingers actually straighten out those kinks.
Hi there, great tips and it has maybe led to solve the bigger issue.
Please take a look at this new screen capture.
I am showing how my rig is misaligned when going back to default skin rig to base mesh.
Maybe there is reason from the beginning how I need to solve the rigging?
Also my eyes updated one time from zbursh GOZ and the mouth did NOT.
Hi Adaptable_Intelligence,
Thanks for providing! Does this mean the Auto bone alignment fixed the fingers?
Thanks @Rampa
Regards
hi Winner_RL
no not at all. What do you suggest?
Do you see these videos?
I think you have the corrective steps out of order. It is going to require both the Adjust bones tool and the Proportion tool.
Step 1 is the automatic alignment of the bones to the corresponding mesh. So in the Adjust Bones tool, click the auto adjust bones. Do not move the bones manually in the Adjust bones tool in this case. This step is only to get the bones aligned with the correct mesh. The fingers will still be crooked, but the bones will match them.
Step 2 is to realign using the Proportion tool. Here you will be moving the bones around, and the mesh will be moved with the bones. Then you just move the bones around until the fingers are straight again.
Basically, Adjust Bones moves the bones within the mesh, and Proportion moves the mesh with the bones.
Could you please send us your working files for us to test?
Thanks
