Frame Rate Settings
I read that you can change the frame rate in the project settings. When I checked it out, it doesn’t really have the option of inputting a different frame rate than the default (30fps). Is this no longer an option? Or is there some other way to change this setting?
Thanks
i would like to know this answer as well
Internally CTA5 runs @ 30fps.
In Project Settings you can change the number of frames in your project up to 27,000 frames or 15 minutes (based on 30fps) but you don’t adjust the render frame rate here.
However, on the Render Settings panel you can adjust the frame rate to 12, 24, 25 or 30fps.
Oh… gotcha… so it’s done post production during rendering… not pre-production. Thanks for your response.
thanks pete
