Facial animations importing into unreal differently
I don’t know if this is a known issue or if I’m just not doing something right, but I’m finding that the facial animations exported from Iclone are always a little different to the ones that import into unreal. The facial shapes don’t seem as exaggerated and there’s a few instances where I know the mouth is together on a ‘P’ or ‘M’ sound in Iclone but separate when it gets into unreal. Has anyone else come across this?
Hi hansagan,
Could you send us a screenshot from both sides? Also, if it’s possible could you send us your working file for us to investigate further? You could send it to winnerhung@reallusion.com or a drive link.
Thank you
Hi Hansa,
I wish I could give you a straight answer here, but I too have the same inconsistencies on bringing over Reallusion assets into Unreal Engine.
Let me ask you a few questions:
  • Are you exporting your character + animation from iClone or from CC4/5 ?
  • Are you using the All-in-One plugin with unreal engine ? I assume yes.
  • On your import settings choices, did you tick the Import Morph Targets option? Also, did oyu set the Customs frame rate to 30 in the Animation section ?
On my side, I have seen some good results and some not so good results depending on the complexity of the animation. If you open up the animation sequence in UE right after you import in, take a look at the curves inside the animation sequence. In theory, those curves should represent your facial expressions exactly as it would look on the “timeline” in iClone.
Its also worth adding that the visual quality fot he characters is also inconsistent meaning the characters always look better in CC4/5 and iClone then they do once in UE.
Hope this helps some.
